RCU Forums - View Single Post - MVVS .45 tunning problems!!!
Old 01-22-2006 | 07:32 AM
nrsantos
Default MVVS .45 tunning problems!!!
Hi!
After a medium start (the only problem was bad transition) with the MVVS .45 (blue head) with 3 months flying and no major problems, lately it has been a TRUE HELL!!!
In my beginning I used a 11X7 prop, but recently I have changed to a 10X6 since I was always destroying the prop tips of the larger 11".
I now use a 10X6 prop and ProSynth 2000 ( I have been told by the shop owner that only has synthetic oil, and later on I read in a forum it has 17.5% content according to a test made by a chemist since no one seems to find out the true oil content of it).
The engine is hard to start;
If I raise the idle it will run OK but at a high idle it is difficult to land. If I set a good idle it always stops after I land!!!
Did I forgot to say that transition still absolutely SUCKS!!!
It chokes a lot and I have had a lot of dead-sticks.
No one seems to be able to set the high end needle correctly, not even those with more experience.
My questions are:
Should I return to the use of a larger prop?
Is it that important to use Castor oil in MVVS engines and a minimum 20% of total oil? Will I see a major improvement if I change my fuel to Castor?
Should I change the idle needle setting? It still is at the factory set 1,2 mm.
Please help me!!!
Nuno
Portugal
