RCU Forums - View Single Post - 10X Programming Question
Old 01-20-2002 | 10:21 AM
jason's Avatar
jason
Default 10X Programming Question
ref your first question. I dont think you could do this using the elevon mix, I think you would need to set it up as a normal wing type and use two channels for the ailerons and apply a mix to each one and select the opperation switch to be the speed brake
switch.
Would that work do you think or is there an easyer way anyone?
Jason
