RCU Forums - View Single Post - Sig Somethin' Extra Build
Old 01-22-2006 | 03:38 PM
  #92
somegeek's Avatar
somegeek
Default RE: Sig Somethin' Extra Build
Got the sheeting and cap strips completed. Removed the wing from the building board and cleaned up the ends.
Gonna wait until I get the fuselage built to install the inside rib cap. Had a little bit of an arch to the rib (maybe 1/32 of an inch) so I wanna see how this sets against the fuselage before I start sanding/truing it up to make sure I do so in a way that it is flush with the fuselage. Nothing major.
Put some putty on the LE since the stock had a bit of a flat side to the lower edge vs being fully rounded.
