RCU Forums - View Single Post - pcm or fm---whats the difference??
Old 01-22-2006 | 07:05 PM
consultjdm
Default RE: pcm or fm---whats the difference??
besides changing your setting on your receiver you need to buya PCM Receiver.
I set mine to about 25% I want to come down but not at blazing speed.
I would try testing it at low throttle levels. and see how hard you fall from a foot hover with training gear on. Think about your Throttle and pitch combo that it takes to get up. and start with a little less. But then you might just want it to shut off. your futaba help line may be able to give you some advice on your heli.
JD
