RE: Reversing Servos
Hay brocja01
I thought I could get away with doing the same thing. Bad things happened! If you want to run more than one model on one TX you should look into an entry-level computer radio like the Tower Hobbies system 3000 6xm, or Futaba T6EXAp. These hold all of your trim and through settings for each model. Also this type of radio makes rigging setup a breeze. If you do a little shopping one can be had for under $100.00
