RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-22-2006 | 09:15 PM
  #1916
medic955
Default RE: E-FLIGHT BLADE CP
miroker check your blades, if the white plastic covering is damaged of torn on the leading edge i/t can start to open at high rpm's. It will act like a dying battery or cause blade spread. If this is the problem then just clean up and CA back down or use balance tape (equal amounts per side). Also check to make sure a paddle on the fly bar didn't twist.
