he says that he gets much more of a buzz from Control Line because you're in direct contact with the plane.
Yep thats just it, plus the ground is closer so you have to have your wits about you all the time, not just when landing that R/C model.
If you want to build from a plan, then the Peacemaker is a good one that is easy to source, tho as I say the fuse and tail should be re-enforced for the first model.
We use "Pro-Film" mostly as it is strong, easy to work with and is Diesel fuel proof ( note that Solar Film isn't Diesel proof )
Tho on our classic combat models we still use Nylon and Dope for ultimate strength.
For instance, a Nylon covered Warlorg combat wing will survive serious crashes time after time without breaking, great for learning basic aerobatics. Silk is often used on those beautifully finished full size stunt ships.
