RE: Big Super Tigre carb fix - replace it!
I normally replace the stock ST 60-90 carbs immediately. The 2300s' carb is good, although sometimes too large to draw fuel well. The low needle is sensitive when you get it close to perfect. I agree with using low nitro with this engine, 5% Coolpower is all I will ever burn in a 2300. The Japanese engines are nitro hogs, they suffer with low nitro.
