RCU Forums - View Single Post - MT2 ground clearance.
Old 01-23-2006 | 04:25 PM
RallyRed 98's Avatar
RallyRed 98
Default MT2 ground clearance.
been having some problems with getting my MT2 around our backyard track. sorry for the noob **** that will follow.
i should first say that the track i run on was built mostly for 1/8 scale monster trucks so the jumps are pretty tall. however they shouldn't be too tall for a stadium truck, and they seem to be. any time i go off one of the two major jumps i bottom out... basically boucing the chassis off the dirt.
i've been trying to get the thing a little higher in the air and so far i have decided to get a taller wheel and tire combo, but i would also like to do some shock mods. last night i refilled them with 40 weight oil and that has made them a little firmer.
would it be a good idea to get shocks with more travel, stiffer springs, or add spring spacers to the stock shock/spring to preload the suspension, or do one of each?
thanks for yer advice.
