RCU Forums - View Single Post - Anyone own a Warhead?
Old 01-23-2006 | 07:52 PM
  #792
IFLY2HIGH
Default RE: Anyone own a Warhead
ORIGINAL: Wide Open
well guys, i got my driveshafts back from hobby services, all i need now is the clutch and ill be good to go. im going to try rebuilding the cv's with some bearing grease to see if they last any longer. ill give you a report once i get it going again.
About how long or many tanks did your cvd's start to wear. I was installing the Proline 23mm Hubs today and had to remove them to shim the axle and I havn't seen wear yet on mine and I've only run about 7 tanks though it so far.
