RE: Help with Blade CP
I was told at the lhs that the fly bar paddles should be flat and even at neutral...that means throttle at low point (for the blade cp, make sure you aren't in the "3d" mode)....also as a prior helo mechanic in a prior life, keep your trims centered when checking this
