I'm only guessing here...
Being 1.71 cu.in. I'd say a .60 size aircraft-if you run it on gasoline.
It may be possible to run it on low nitro 2-stroke glow fuel. You'd have to make a reducer to fit in the sparkplug hole then drill and tap the center for a glow plug. This may offer higher rpms. What about the carb????
Prop? I'll take a stab at a 15X6.
I think it would be fun to play with and experiment.
Remember: I'm only guessing!
