EPA HOW TO
on the fw 190 im about to finish. ive got all the control rods set. the one problem i see is that the when the throttle is wide open the servo arm passes the wide open point and ends up bending the throttle rod. can i use epa to adjust this. and how would i. or should i try to move the connecting rod closer to the servo?
