RE: Futaba 14MZ discussion.
Lance,
I've used mine with the 14ch Rx set at the standard length with over 150 flights on various planes and no problems (all turbines). Also the Tam F 18 was setup with a whip antenna with no problems, but she has only had a dozen flights at best so far. The baby Boomerang was setup with a Deans antenna with about a 100 flights or so with no problems also. Last, used a Deans antenna on a turbine jetcopter by a friend of mine with about 20 or so flights with no problems also. I hope this helps.
Sung
