I glassed the wing joint on my Four Star ARF, just because I wanted a little extra strength there. I knew I was planning on wringing this plane out pretty hard, though. The hardest part was getting the covering off around the center section! I didnt use resin or epoxy either one on mine, just tacked the glass fabric down good and saturated it with thin CA. Works well, just a bit harder to sand. If you are planning on flying this plane hard, I'd go ahead and glass it. I'm not sure it really needs it, but hey, it cant hurt, right? Since your's is a kit, I'd definitely go ahead and do it!
