RE: Top Flite 1/7 P-51 Build
asphalt252,
Thanks for the reply. I have not found out why the cut out in the W-2 is larger ( forward and aft ) of the spar. But, it does appear from the plans that sheer web might go in there. I just glued it where it's supposed to be and all is working out fine so far. The note pad sounds like a very good idea. that way I dont put two 3/16 inch spars in the aft spar location again ( supposed to be one 3/16 inch and one 1/8 inch piece ). It took a lot of sanding to get the 1/16 th inch gap, I needed for the flaps, after that mistake. Ill try to post pics tomorrow.
