RCU Forums - View Single Post - Trouble With Straight Loop With T-34..Ideas?
Old 01-25-2006 | 07:34 AM
ashley95
Default RE: Trouble With Straight Loop With T-34..Ideas?
try this just to make sure while on the ground as if you are doing a loop watch your control surfaces closely make sure you're not getting some wierd interfernce causing the rudder to move slightly at full throw or you dont have a mix added in by mistake. also check your thumbs to make sure you dont have some slop in the right stick of your transmitter
let us know good luck
