Specifications for K4.6 High Output (#15204)
Displacement: 4.59cc
Bore: 18.6mm
Stroke: 16.9mm
Practical rpm : 3,100 ~ 39,500 rpm
Maximum Horsepower at RPM: 2.95 hp @ 38,000 rpm
Maximum RPM : 41,000 rpm
Carburetor
Type: Composite Slide
Bore: 9.0mm with 8.0mm and 8.5mm reducer
Nitro Star K4.6
Size 4.6cc (.28cubic inch)
Horsepower @ RPM 2.9 @ 35,000
Maximum RPM 39,000
Bore 18.6mm
Stroke 16.9mm
Construction ABC
Heatsink Head Purple Anodized Machined Aluminum
Carburetor 8.5mm Composite Slide Carb
Carb Adjustments 3 Needle, Flush Settings
Case Silver Aluminum, Rear Exhaust
Connecting Rod Dual Bushing
Sleeve 8 port
Starting system Pullstarter
Recommended Glow Plug #1504 Cold-R5 Power
CAN'T SEEM TO FIND THE SPECS ON THE NEW MOTOR I'LL KEEP LOOKING BUT I THINK IT WAS LIKE 2.65 OR SOMETHING LIKE THAT IT SEEMS TO BE A HOPPED UP .25 MOTOR sorry for yelling so much
