ORIGINAL: rctom
FYI this is the exact same plane as the 41%, just scaled down. With a DA-50 it had way plenty of power (as you might expect with the plane under 16 lbs). It was a little tail heavy with batteries back by the receiver. I'll move them up front next, we had to add 4 oz. to the nose of the DA50 to get it to neutral. It will probably be OK with Rx. batteries in front and a bigger ignition battery.
Stay tuned, this plane is really excellent and we will get it into production asap.
TF
Sounds like a good plane to test out the new Kroma 50!
