RCU Forums - View Single Post - BRIO Construction by the numbers
Old 01-25-2006 | 08:39 PM
  #33
Don Szczur's Avatar
Don Szczur
Default RE: BRIO Construction by the numbers
With regard to the fuselage cutout holes, I leave them open. I have not had any issue with fuel getting into that area. With regard to the plug-in stabs, I also use #4 sheet metal screws that are tapped into the stab tube. Shown are some pictures of my current Brio in this regard. Plus a picture of the tailwheel assembly. I used 1/32 in ply as a re-inforcement for the tailwheel bracket, if you can see this in the picture.
ID:	395345   Click image for larger version
ID:	395346   Click image for larger version
ID:	395347   Click image for larger version
