Started on the right wing build...
Also got the wheel pants cut out(Dremel ftw!) and glued up. Used a different method then called for in the instructions(read about in another SSE thread)...[ul][*] cut out the areas that form the holes for the wheels.[*] sand down each side on sandpaper.[*] sand the inner surface near the seam.[*] tape the sides together along the seam[*] apply epoxy to the inside seam
[/ul]
I need to touch up the holes a little for asthetics, but the wheels just fit through the hole so I am set. Will also need to use some filler on them to smooth the seam.
What kind of filler can I use to fill any low areas in the seam of these plastic wheel pants?
somegeek
