ORIGINAL: somegeek
I need to touch up the holes a little for asthetics, but the wheels just fit through the hole so I am set. Will also need to use some filler on them to smooth the seam.
What kind of filler can I use to fill any low areas in the seam of these plastic wheel pants?
somegeek
When I did mine, I used med. CA to glue the halves together and then put a bead of med. CA along the seam. Then I finished the joint off with a fine mill file followed by fine sandpaper. That worked well for me since I covered the pants with Ultracote. Painting might require priming and sanding to get a better finish.
