RCU Forums - View Single Post - G forces
Thread: G forces
Old 01-26-2006 | 08:14 AM
mesae's Avatar
mesae
Default RE: G forces
Since you plan to physically test an existing structure, I guess there is no need to worry about the engineering involved in designing a structure to withstand those forces.
180 deg in one second is 30 rpm.
30 rpm is 1800 revolutions per hour.
1800 revolutions in one hour = 250 miles.
1800 * 2 * pi * r = 250 mi.
solving for r,
r(adius) = 116.71 ft (35.57 m).
a = v^2 / r
where a = acceleration, v = velocity and r = radius
250 mph = 111.76 m/s
a = ((111.76 m/s)^2)/(35.57 m) = 351.15 m/s^2
1 g = 9.81 m/s^2
351.15/9.81 = 35.8 g
That's a lot of g's, but not unreasonable, if one has ever watched a formula 1 model airplane race.
Remember, there is at least a 50% safety factor built in to small full-scale aircraft. So the structure must not fail up to at least 54 g if you follow that practice. With a model and no telemetry, I would feel better with a 100% safety factor, or 72 g!. Don't forget to consider the loads on the stab/elevator, and the fuselage and engine mount.
DISCLAIMER: I am not an engineer, and I'm not liable if your plane breaks anything, or hurts anybody. These calculations and $3.50 will get you a cup of coffee at Starbucks!
Good luck, and be careful!
P. S. Dick, are you reading this? A few minutes work on a scratch pad can provide data for ground testing that might prevent an in-flight structural failure. I'd sure rather have it fail on the ground during a test than in the air!
