RE: ss prop shaft
I would/always use a stainless steel shaft no matter what kind of water I would be running in. If you were using a plain steel shaft and any water or moisture would get to it, it would rust. If left long enough the rust would build up to a point where the shaft won't turn anymore.
Running in saltwater does require you to do a tear down every so often to clean and lube things up.
