Painting For Dummies
If you have to leave the tape on for second coats hit it with some 600 grit wet. Just run the paper down the tape lightly and it should break the spots that cause it to pull paint up. I usually try to pull the tape as I the paint is drying though. I use the DBC paints like John mentioned and you can mask the next color within 15 about minutes.
