RE: Maxair Revolution II Velox
Barry the reason for my servo choice is the servos I have are all plenty strong enough to go any where on the plane. I wanted the quicker servo on the rudder as I feel I need the speed the most on there for corrections while hovering. I usually run with no expo on the rudder and start with about 30% on the elevator and ailerons. I change that after I've flown the plane a bit. If I had them I would have used 5625's all around. If I don't like it I'll put something stronger on later. The elevator halves could likely use a 5475 but I had the otheres so I went with them. My Harrier has 475's on all surfaces except the rudder which is a 5625 and I have never had an issue with them. I took a couple more pics at lunch. I have 2 sig tailwheels ordered because of reading your input in the Showtime thread. If they show up before I have achance to fly the plane, I will change it. Here's the rudder installed and a pic of the tailwheel.
Don
