Bobs analogy with the weedwacker is incorrect. turning the weedwacker at high rpms is difficult, this is due to gyroscopic forces. If what Bob had said was true(and what you are saying is true with this boat), the weed wacker would try to twist out of your hand when it's throttle is gunned(you say it would twist perpendicular to the driveshaft - it will torque in your hand, but along the same axis as the driveshaft), It does not; it only tries to stay in the same orientation (like a gyroscope). An engine, unmounted, and sitting on the ground, will vibrate and 'walk' due to the vibration, but not due to the force of the piston being 'blown' one way and comming back the other
Actually ... no .. it is not incorrect .
I did NOT mean that the engine would rotate in your hand ... but rather the "feeling" you get of the engines power stroke .
If you doubt what I say , then do a simple test ....
Take that engine ... set it on a axis ( sideways - like the way that engine is mounted ) and watch that sucker spin sideways in a circle .
( sorry ... but it DOES happen . I JUST finished doing exactly thie with a TANAKA 16 cc engine )
Now , take the SAME engine , and place it up-right ... and it does NOT rotate like it does when placed on its side .
( tested and proved - sorry ---- need a video ?????? )
