RCU Forums - View Single Post - Pushrod installation ? Need to glue tubes ?
Old 01-26-2006 | 10:26 PM
cyclops2's Avatar
cyclops2
Default RE: Pushrod installation ? Need to glue tubes ?
Always glue the pushrod tubes at least near each end. NOT to close, do not cause binding as the servo swings full stroke. NEAR the servo and as it goes out the body in the tail.
Longer runs sometimes flex if unglued in the body. If you cycle the tails and put some finger pressure on them and the cable does not "squirm " , you are OK.
