RCU Forums - View Single Post - steerable nosewheel
Old 01-27-2006 | 10:01 AM
Rodney
Default RE: steerable nosewheel
One caution, when you hook up your nose wheel steering, do not over do the throw. You only want about plus or minus 5 degrees travel on the nose gear with full rudder deflection. Usually use the hole closest to the servo center at the servo end and use the one farthest out at the nose gear tiller arm.
