RE: Ouch
use a piece of fuel line or similar on the shock shaft to stop it using the full travel of the shaft. by putting the fuel line on the shaft outside the shock body, u will limit its compression, and by fitting it inside the body, under the piston, u will limit down travel/droop. each shock will have to be done equally and accurately to avoid strange handling.
cenracer - what are u using to limit it?
