RCU Forums - View Single Post - Measuring Thrust
Old 01-27-2006 | 11:08 AM
Newc
Default RE: Measuring Thrust
Too bad about the experiment! One thing to keep in mind is to carefully re-check the CG after your rebuild/repair. You are likely to be tail heavy as a result of the materials and epoxy used for the repairs, and I don't want your next trip to the field to end up with a tail heavy plane that goes in!
Good luck.
