RCU Forums - View Single Post - Adjusting OS .46 FXI
Old 01-27-2006 | 03:35 PM
bruce88123
Default RE: Adjusting OS .46 FXI
Yes. Then doublecheck the high. Once you get the low set, you will seldom need to touch it again unless the engine goes to a much different climate/altitude. OS seems to set the idles slightly rich to protect the engines from damage that can be caused by a lean run.
