Ryobi RPMs ?
I have a twin ring Ryobi 31 without the compression relief slots. Should be pretty tight. It's a brand new engine.
I'm using 40:1 chainsaw oil in it with a 3-blade Master Airscrew 16-8 prop. Getting right at 6000RPM--maybe 6200RPM. The tach fluctuates a bit.
I had a Top FLite 18-10 on it and got about 5200RPM from it.
It has a Zama carb. Stock carb--couldn't tell ya what size it is.
What kind of RPM should I expect out of it?
Does anyone know the biggest carb I can put on it? I used to know a Walbro number--but I'm getting old. Seamed like it was a WT438 or a WT 343--something like that. It has the same opening as the hole in the backplate of the engine.
Do you think it'll get stronger as it gets some time on it?
