RE: Futaba 8UAP TX how good is it?
I have both the 8uap and a 8uafs both are good radios and this might sound like dumb thums but be careful when you hit the down trim buttons on either side of the power switch, I went to trim some up elevator and hit the power switch instead, loss of one Laser 2000. I went home and changed the switches to toggle switches, the ones you have to pull up on to change postions. Never had anything like that happen before but just be carefull. You can also pull the power switch button off and still reach the actual switch to turn it on.
