RE: V24 OWNERS:Mods and Solutions
Good Idea for mods threads. I own 2 of these boats. They are good but you need to strip them down and redo (loctite) alot of stuff. The first main problem and probably the biggest is that on both boats that I own the throttle servo setup from Factory only lets the throttle body open 2/3rd full. Its makes you wonder how many boats are running out there being called slow only because of factory linkage screw up? Anyhow I will post mods and setups for this boat as I put more run time on it.
