RCU Forums - View Single Post - 4-Stroking an ABC engine while break-in
Old 01-28-2006 | 02:43 AM
Motorboy's Avatar
Motorboy
Default RE: 4-Stroking an ABC engine while break-in
ORIGINAL: Khizer
Rcpilot,
90 % damage to an engine occurs as a result of starting friction ( Taking the assumption that the engine is not run lean or overheated by over proping) when the engine is not wet with fuel.
I wish we had a lube for R/c engines which had polarized molecules to reduce this wear.
Khizer
Khizer
The engine are allready overlubricated (between 15% and 33%) after the engine are primed and very very very little to damage the engine while starting the engine.. I has many modelengines from 1950 to modern engines.. they are still in good contition and good compression.
The castoroil is highly polar and has a great affinity for metal surfaces. Castor oil are better to care the engine than syntetics oil, read here: http://modelenginenews.org/faq/index.html#qa5
Jens Eirik
