ORIGINAL: andrew66
another question: a little off topic, but should i balance my model before covering it and then rechecking after or just do it after? my instructions dont reccomend wich is better. i personally think that adding weight if necessary before covering would be better cosmetically speaking. just my opinion, but if its better the other way, ill just do that
Balancing it before you cover is the best way - if you can do it.
Then cover and recheck.
This keeps the AC clean and neat. Any extra weight that you add afterwards will be minimal.
