Sceadu Starting System
It is slightly dangerous starting the heli that way. What if one day the wand doesn't just pull out, and instead the engine flings it at you or your heli?
Regarding the coupling. There are several heli guys with lots of experience that say there is indeed a problem. I believe them. Reportedly the problem has been tracked down to defective swashplates(the inner balls are not on the same plane as the outer ones).
