RCU Forums - View Single Post - ST2300 Testing and Experimenting
Old 01-28-2006 | 05:38 PM
Flyer95
Default RE: My 2300 only likes one prop
Maybe the muffler is restricting the engine at those higher rpms?
Also two more things to try would be too remove the headgasket to raise the compression with the lighter load and also lean the idle needle slightly maybe about 1/16 of a turn and try again. Good luck
