RCU Forums - View Single Post - new boat, same problem
Old 01-29-2006 | 01:42 AM
  #45
crispyspa's Avatar
crispyspa
Default RE: new boat, same problem
Chris, I also found some specs on my engine:
YEAR INTRODUCED: 1986
YEAR DISCONTINUED:
ENGINE DISPLACEMENT: 2.4 cu. in. (39.3 cc)
NUMBER OF CYLINDERS: 1
CYLINDER BORE: 1.563 in. (40 mm)
PISTON STROKE: 1.250 in. (32 mm)
CYLINDER TYPE: Aluminum with chrome plated bore
INTAKE METHOD: Reed valve
MANUFACTURER ADVERTISED H.P.: 2.16 SAE @ 8,000 RPM
WEIGHT : 9 lbs. 12 oz. (4.4 kg.) powerhead only
ID:	397505   Click image for larger version
ID:	397506   Click image for larger version
ID:	397507   Click image for larger version
ID:	397508   Click image for larger version
ID:	397509   Click image for larger version
ID:	397510   Click image for larger version
ID:	397511   Click image for larger version
