I wonder if every kit has the same problem with the horz hinge being mounted too low. It did take long to make to make the spacer, in fact I still have some of the plywood I ripped left. Stop on by and I give it to ya
I'm about to start mounting the servos in the wings. How is the hardware on your kits? The hardwood blocks supplied with mine look like they were cut out with realy dull teeth. I am planning to make new out of stock I have laying around.
Ideas for wiring the wings? I'm thinking of using bulk cable and soldering to the servos so I could hide the leads inside the wing wiring channel.
