RE: My 2300 only likes one prop
There is an overall higher load with the bigger pitch prop and the engine needs more fuel/rev. to handle the higher load. When you are lowering the load by using the 18x6 instead of the 18x8 the engine needs less fuel/rev. from idle to full throttle. So both needles needs adjustments.
