Cosmic Wind
Marty,
Mine is a 64-in. span, 750 squares, 8.5 lbs flying weight. You could use all standard radio gear and hardware. It's designed for a .90 2-stroke, so the YS 1.40 4-stroke would be slight overkill but not out of the question. The aerobatic performance with a .90 was a pleasant surprise. I'll bet you could hover it with the 1.40.
I pulled a mold from my built-up prototype, so if you just can't find what you need anywhere else, write me back and maybe I can put together a fuselage, wing cores and plans for you.
Duane
