RCU Forums - View Single Post - Adding LED Lights. How To.
Old 01-29-2006 | 06:13 PM
Shadrack
Default RE: Adding LED Lights. How To.
I stripped the wire, both + and -, where the battery connector leads to the 4-1. Used a sharp blade and just trimmed a bit of insulation off, put a small bit of solder on when holding the thin wires from the led's, confirmed that it worked, and then coated the bare area's with some epoxy to insulate again. Works great.
