RE: steer straight
Remember guys this is a huge truck and at the speeds it hits it can wonder because of the tire size.
If you suspension is setup soft it will make the truck wonder at speed also. Try stiffing up the back some to see if it helps.
You can add a swaybar also to keep things in check.
Other than that hang on it's one heck of a ride when this beast gets on the pipe...
