RE: Cant get engine to run right
Yeah....get rid of those air bubbles!!!!
You can twiddle needles, and adjust valves until the cows come home and you won't fix anything as long as the engine is drinking foam.
Either your fuel is foaming, the tank is garbage or the lines are leaking somewhere. The motor absolutely will not run properly until you get this ironed out.
