RE: invert question
Pitch is the angle of attack for the blades. If you have positive pitch, you go up, negative pitch, you go down. If you roll into inverted flight, the controls are reversed. negative pitch makes you go up, and positive pitch to go down. If you are not careful, and roll into inverted flight and do not adjust yourself at the controls, you will simply fly straight into the ground. Hope this helps some.
