RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 01-30-2006 | 02:48 AM
  #2008
batfalcon's Avatar
batfalcon
Default RE: E-FLIGHT BLADE CP
Guys I need your help on this one.
Some days ago I wrote you about a problem I am facing with the swash plate's travel. On these 2 videos you can watch the travel in both modes.
The problem is that if a set up the pitch to be 0 at middle stick and 3D on, then the heli won't leave the ground. If I add pitch, as I did, it flies ok, but it's impossible to have negative pitch
I need you to watch closely those travel distances of mine ,compare with the ones on your helis and tell me if mine are correct or less.
The first is a close up of the swash plate at Normal mode (not 3D).
http://www.zippyvideos.com/211581371...ve_pitch_0001/
The second is the same at 3D mode.
http://www.zippyvideos.com/144172455...ve_pitch_0002/
And it flies like this
http://www.zippyvideos.com/487951120..._version_1_3c/
