RCU Forums - View Single Post - removing press-fit pinion from shaft
Old 01-30-2006 | 09:54 AM
exeter_acres's Avatar
exeter_acres
Default RE: removing press-fit pinion from shaft
I have used a soldering iron...
heat up the shaft with the iron and then GENTLY pry the gear up and off....
works fine IF done carefully
