Hi Josh thanks for the fast reply, i went to your site today and watched the flights, I am inspired, nice looking children too
I am also inspired by the rudder set up.I will be using the Evoultion 58 this motor is about a pound heaver than your DA, I am going to call Graphtec and get a wing tube, horizontal stab and landing gear in CF, I am wondering with the weight saving if the mod on the rudder will be needed??, I so dislike adding weight to balance my models so I want it to balance with the gear used by maybe moving it around, do you think it needs a powerbox?? for servo's batteies I am going to but a Hitec Digital servo programmer instead of matcbox's.I am also flying with a 9 c super, do you have a y harnes on the two sero's in each wing and then use two channels mixed with independant mix on the radio???? I have a Dave Patrick ultimate using 4 channels for the aielrons. dont like to use three y harnesses. This will be my first gas plane and first biggish one I have a funtana 90 which is the biggest I have flown, is the transition from glow to gas and the size an easy one??? you certainly made yours look easy to fly...it looked like it landed pretty much on it's own, even the take off...man that was a short rollout!!!! [X(][X(] Thanks Kind regards Colin.
